Installing Recalbox takes three steps: pick your device, flash the image onto its storage media, and let it run its first boot. Allow about thirty minutes, download included.
Recalbox 10.1 is available for the following devices:
| Device | Image |
| Raspberry Pi 5 (and Pi 500) — the team's choice! | recalbox-rpi5_64.img.xz |
| Raspberry Pi 4 / 400 / CM4 (also GPi Case 2 and PiBoy DMG) | recalbox-rpi4_64.img.xz |
| Raspberry Pi 3 | recalbox-rpi3.img.xz |
| Raspberry Pi Zero 2 (standalone or in a GPi Case 2W) | recalbox-rpizero2.img.xz |
| 64-bit PC, including Steam Deck — see Compatible PCs | recalbox-x86_64.img.xz |
| Odroid Go Advance / Go Super — see Odroid | recalbox-odroidgo2.img.xz |
| Anbernic RG353 (M/P/V) and compatible handhelds — see Anbernic | recalbox-rg353x.img.xz |
Older hardware: the Raspberry Pi 0/0W/1 and 2, the Odroid XU4, the GPi Case v1 and 32-bit PCs are no longer supported by Recalbox 10. Their last images remain downloadable from the download page, but they are no longer maintained.
Missing something? The Recalbox shop sells complete, ready-to-play kits: a RecalTower case with a Raspberry Pi 5, SD card, power supply, fan and HDMI cable. It also carries the RGB DUAL 2 and JAMMA boards, controllers, arcade sticks and video cables.
Everything starts from the official download page: recalbox.com/download/stable. Pick your category, then your device, and follow the on-screen instructions.
Recalbox is built right into Raspberry Pi Imager (Windows, macOS, Linux) — no need to download the image by hand:
CHOOSE OS → Emulation and game OS → Recalbox → your Pi model.CHOOSE STORAGE → select your microSD card.WRITE — the image is downloaded and written automatically.recalbox-xxx.img.xz file) from the download page.CHOOSE OS → Use custom and select the downloaded .img.xz file.CHOOSE STORAGE → select your microSD card or USB stick.WRITE.Never uncompress the
.img.xzfile: the flashing tool takes care of it itself.
- Flashing erases everything on the card or stick. - Only the latest version of Recalbox is available: older versions are neither downloadable nor supported.
SHARE partition (exFAT) that will hold your games, saves and settings — while a presentation slideshow plays.
The installation takes a few minutes depending on your hardware. Do not cut the power during this step.
When the system selection screen appears, you are done! Head to First use to set your language, configure your controller and play.
F8, F11 or F12 at startup depending on the manufacturer (sometimes Esc or Del).Once you have tried Recalbox from the USB stick, install it permanently on the PC's internal disk without any external tool: START → SYSTEM SETTINGS → INSTALL TO....
➡️ The step-by-step guide: Install Recalbox on an internal disk
F8/F11/F12) to pick the Recalbox disk, or put it first in the boot order.| You want to… | Head to |
| Take your first steps (language, controller, first game) | First use |
| Add your games | Add games |
| Install Recalbox on a PC's internal disk | Install on an internal disk |
| Build a GPi Case 2 handheld | GPi Case 2 + Dock |
Need help? Join us on Discord.
