Relive the unique feeling of retro consoles: insert a card into your Recalbox to launch the game of your choice!
The Card Reader and RecalCards turn your Recalbox into a real cartridge console, easy to use and fully plug and play.
The reader has its own page on the website: Recalbox Card Reader — how to program a card, the collector RecalCards, and where to order it.
The Card Reader requires Recalbox 10 or newer, on a Raspberry Pi 5.
Download the Recalbox image for the Raspberry Pi 5 from the official download page, then follow the installation guide.
The Card Reader lets you:
When you insert a card for the first time, a popup explains that you need to associate the card with one of your games in Recalbox.
From the Recalbox menu, press START on a game to associate it with a card.
You can associate two games per card: one for the front and one for the back.
If you want to change the game associated with a card, simply insert the card into the reader, exit the game with the controller (HOTKEY + START), and associate a new one with the START menu.
If you ordered your Card Reader as an add-on, you already have your RecalTower.
To mount the Card Reader floor on your RecalTower, simply:
Version without RGB DUAL 2:
Version with RGB DUAL 2:
Start Recalbox: the system detects and installs the Card Reader automatically!
Recalbox lets you enable Console mode in the RecalCards options. This mode shows a home screen instead of the usual Recalbox menu, from which you can only run the games linked to your RecalCards.
To enable Console mode, open the Recalbox menu by pressing START, then go to the RecalCards settings.
In this menu you can:
HOTKEY + START combination, or holding the START button for 5 seconds);Once Console mode is enabled, restart Recalbox to access it.
Console mode looks like this:
For the game to run, at least one controller must be connected to your Recalbox. All you have to do then is insert a RecalCard and play!
You have received your RecalCards and want to do better than writing the game name on the stickers, by putting the logos of your favourite games on them? A label generator is available at https://recalcards-gen.recalbox.com/.
Here are the steps to use it:
From the official store: Recalbox Card Reader + 10 RecalCards.
For any question or suggestion, or to share your custom label designs, the #card-reader channel is available on the Recalbox Discord server.
Allow Boot On Game option in the RecalCards settings (START → RecalCards settings).
