A theme is not set in stone: most of them expose their own options — colour set, icon set, system list layout, game list style, retro filters… These settings come from the theme itself, so they differ from one theme to the next.
Two paths lead to the same screen:
Y (OPTIONS);START → MAIN MENU → USER INTERFACE SETTINGS → THEME.
The difference is slim: the THEME menu of the interface starts with the active theme selector, while the screen opened with Y from the manager goes straight to the current theme's settings.
Any change is applied immediately, without rebooting: the theme is reloaded on the fly.
Under the GLOBAL CONFIGURATION header:
| Setting | Values | Purpose |
THEME SET |
The list of installed themes | The active theme (only in USER INTERFACE SETTINGS → THEME) |
CAROUSEL ANIMATION |
On / Off | Animate the system carousel during transitions, or not |
DEFAULT TRANSITION STYLE |
ZOOM, FADE, INSTANT |
The transition between two systems: sliding, fade to black, or no effect at all |
REGION |
Europe, USA, Japan |
The region to use for themes offering regionalised artwork or texts (console logos, system names…) |
CAROUSEL ANIMATIONandDEFAULT TRANSITION STYLEappear greyed out when the active theme enforces its own transitions — which is the case of the defaultrecalbox-nexttheme. This is not a bug: the theme has the final say.
Under a second header carrying the theme name (<theme name> CONFIGURATION), Recalbox lists the options declared by the theme, in the form Select <option name>.
The name, help text and values of each option come from the theme, and are shown in your language when the author translated them. A theme may expose none at all, or a dozen and a half.
recalbox-next theme| Option | What it changes | A few values |
SYSTEMS : Layout |
The system list layout | Vertical left, Horizontal center, Horizontal bottom, Top, Wheel left |
SYSTEMS : Display informations |
The information shown on the system list | Show full informations, Show light informations, Hide informations |
GAMELIST : Layout |
The game list layout | Standard, Controls, Standard - Big Picture, Large list |
Display games information |
The game information shown (CRT/JAMMA displays) | Show games informations, Show synopsis |
SCREENSAVER : Clip style |
The game clip view layout | Detailed, Big cover, Full video |
GLOBAL : Theme Colors |
The interface colour palette | Systems Colors, Random, Blue, Green, Grey, Orange, Pink, Purple, Red, Yellow… |
GLOBAL : Retro Shader |
A retro filter over the interface (HD/Full HD) | CRT, Scanline, Honeycomb, None |
GLOBAL : Shadow |
The background gradient (CRT/JAMMA displays) | No shadow, With shadow |
GLOBAL : Colored bands |
The decorative colour bands | Slim, Fat, Hide |
GLOBAL : Helpbar icons set |
The icon set of the help bar at the bottom of the screen | Depends on the theme |
This table gives the flavour, but every theme has its own: open the menu to discover what yours offers.
Some options do not appear depending on your hardware: a theme may restrict an option to CRT/JAMMA displays, to high definition, or to TATE mode. The same theme therefore does not show the same list on a Raspberry Pi over HDMI and on a JAMMA cabinet.
Each option is stored in recalbox.conf, per theme, in the form emulationstation.theme.<theme folder>.<option name>:
emulationstation.theme.folder=recalbox-next
emulationstation.theme.region=us
emulationstation.theme.carousel=1
emulationstation.theme.transition=slide
emulationstation.theme.recalbox-next.bands=1 - Slim
emulationstation.theme.recalbox-next.colorTheme=0 - Systems Colors
Because settings are stored per theme, switching theme does not lose the settings of the previous one: you get them back untouched when you return to it.
The stored value is the raw value declared by the theme (often prefixed with an ordering number, such as 1 - Slim), not the translated label displayed on screen. If that value no longer matches anything — because the theme was updated and the option renamed, for instance — Recalbox falls back to the first available value and fixes recalbox.conf for you.
colorset, iconset, menu, systemview, gamelistview, gameclipview) get a translated label enforced by Recalbox (Select THEME'S COLORSET, Select THEME'S GAMELISTVIEW LAYOUT…), which overrides the title declared by the theme. Theme authors who want to keep control over the label use a different option name.gameclipview also gets a DEFAULT value added automatically by Recalbox, which lets the interface pick the game clip view itself.<subset> tag — how a theme declares its options, from the authoring side.<include> tag — how a theme declares the values of an option.
